truck manifold build
Im starting a truck manifold build and ran into a few problems with the engine plate in the way. Here is the break down : Cid 408 Diamond Pistons -28 Compstar crank & rods Total seal rings Melling oil pump Comp Cam Gm lifters Manley timing set Wolfe mini tub,subframe conn,manule rack,AJE Racing K-member struts A-arm *Need input on engine plate problem, Turbo system, Heads, Fuel system, Gear ratio, Engine management. If im missing something please let me know.Pic of engine is in album, didnt know how to post with thrend. Trying to make 1000hp
