motor mounts
Old 01-17-2009, 02:22 PM
mark a's Avatar
Smile motor mounts
i think i need new motor mounts my motor shakes pretty bad i have a torquer v.2 the lsa is 112 the car is a camaro z28 i need help to pick the best mounts for my car in one other thing how hard is the job.
Old 01-17-2009, 02:24 PM
00_STANG_KILLER's Avatar
POlyurathane by energy suspension. If you have a lift not to bad but if your on jack stands its not gunna be fun Good luck.
Old 01-17-2009, 02:29 PM
01ssreda4's Avatar
prothane from summit for about 55 shipped. its not bad to do if you know your way around the car and have some tools.
Old 01-17-2009, 02:51 PM
outkast6991's Avatar
as everybody above said it isn't too bad. my advice is make sure you have a 13mm rachet wrench and some patience. also don't forget about the small electrical connection on the top of the alt. it will break very easily. i did my solids on jackstands and it took about 5 hours with a bunch of cursing breaks. take your time
Old 01-17-2009, 10:59 PM
LS199CAMAROZ28's Avatar
even with a lift it sucks. be sure to have a big pry bar and take lots of breaks.
Old 01-17-2009, 11:07 PM
DVS99TRANS's Avatar
+1 to that. I had to compress the passenger side mount about a 1/2" to 1/4" while I already had the driver's side installed. I will tell you this that motor isn't coming off until it is motor swap time or Kmember time lol. But on a positive note, the driver's side was a breeze. Just which ever one you install second will have you cussing like a mad man
Old 01-17-2009, 11:23 PM
HavATampa's Avatar
I changed mine while I had the heads and exhaust off, no big deal. It's got be a real bitch to do with headers/exhaust in the way.
