Will it run like this???
Old 01-17-2009, 09:02 PM
Raven97's Avatar
Default Will it run like this???
I have built a 355 with a CC306, 36lb injectors, !EGR, !AIR.
Will this motor run at all on a stock tune? I really don't want to have to ship the pcm out only to take it right to a Dyno shop, and I don't want to pay the dyno shop to do the initial break in, so will the stock tune be enough to get it to run till I can get it to the dyno shop?
Please please help!
Old 01-17-2009, 09:03 PM
Raven97's Avatar
Also it only has the Upstream O2 due to longtubes
Old 01-17-2009, 09:11 PM
engineermike's Avatar
Put the stock injectors back in and it will be driveable. May not idle very well, though.
Old 01-17-2009, 09:46 PM
LSWHO's Avatar
Yeah, you'll flood the motor with larger injectors and no tune.
Old 01-17-2009, 10:05 PM
Raven97's Avatar
okay I guess I will have to ship my pcm out then. Who is the best PCMforless or who?
I dont have the stock injectors.
Old 01-17-2009, 10:10 PM
You can try and turn the fuel pressure way down, if you have an adjustable regulator.
PCMforless is a good one.
Quick Reply: Will it run like this???
