Moser 9 inch wheel studs
Old 01-20-2009, 11:16 AM
slobird's Avatar
Default Moser 9 inch wheel studs
Tried searching but not much info. Time to upgrade the wheel studs on my son's Moser 9 inch. It has the standard 12mm that it came with. What size will be best and where is a good place to get some studs (ARP?) and lug nuts that will be NHRA legal? Running Pro Stars on the rear, thanks!
Old 01-20-2009, 01:28 PM
TT632's Avatar
Anything will be legal per NHRA as long as you have the diameter of the stud penetrating the hex portion of the lug nut. You can get with Strange or Moser to order replacement studs. I use 5/8 studs with Nuts and sleeve, but you will have to drill and tap the axle flange if you are going up in size.
Old 01-20-2009, 03:25 PM
SuperSlow02's Avatar
1/2x3in from moser for about 20 bucks. Id recommend ARP chromoly studs though, I always seem to strip one stud a year, and if you have ABS, thats a $120 repair.
Old 01-20-2009, 03:42 PM
slobird's Avatar
Was leaning towards the 1/2 x 3 inch ARP's. Any idea what the part # is and where to get them?
Old 01-20-2009, 08:08 PM
not sure on the # but it should have a .685 knurl for press in
Old 01-21-2009, 04:29 AM
EPP
EPP's Avatar
pm returned. Thanks. Bob
Old 01-21-2009, 11:37 AM
wht01ws6ta's Avatar
Definitely get ARP studs. I snapped the one of the standard studs that came with my Moser axles just trying to drive it into the stud hole
Quick Reply: Moser 9 inch wheel studs
