Starter Help
Old 01-20-2009, 09:19 PM
Bruser's LS1's Avatar
Default Starter Help
Here is the problem. The starter is working on a tester, but there is no voltage getting to the sending wire. Also is seems as if the relay is not clicking as well even when its been changed out. The car is a M6, but was a auto before with the gear selector still installed..weird I know. Over the pass month the car would not start occasionally, but moving the shifter into different gears would get it going. The car does start without the clutch engaged. I am lost and need to know where I can begin to solve the problem. Thanks!
