Notices
WTB: part for a 10 bolt ASAP!!!
Old 01-22-2009, 02:54 PM
Badazz 97 TA's Avatar
Default WTB: part for a 10 bolt ASAP!!!
what i need is pictured below. there are two round metal plates on each side that act as spacers to keep the rear carrier from moving around. i snapped one in half while i was installing it.
here is a picture. obviously circled in red with the yellow lines is the part i need. if anyone has one lying around i will take it. i only need 1 but if you have two of them i will take them both. either post in here or PM me.
Old 01-22-2009, 03:38 PM
WYATT318MOPAR's Avatar
Those are machined spacers, you probably need to mic your and see what the thickness is that way you can get another one relatively close or the same and don't throw off the setup of the carrier. Otherwise you get to do the ring gear setup all over again. Must have been a damn big hammer you were using.
Old 01-22-2009, 03:46 PM
alright. thanks for the info. maybe i will hit up the dealer. you wouldnt happen to have a part # would ya?
and it was a normal size hammer . the cold weather probably didnt help. i wasnt hitting it that hard either.
Old 01-23-2009, 06:37 AM
bump.!
Old 01-23-2009, 09:38 AM
DMH Fabrication's Avatar
Any shop around you that does rears will have the spacers. As posted above, you need to get the correct spacer or your gear pattern is not going to be correct.
Old 01-23-2009, 10:53 AM
FirstYrLS1Z's Avatar
you have to get an EXACT(in thousandts of an inch .001) replacement or the gear lash will change(which sometimes can be an improvement).
Old 01-23-2009, 01:01 PM
carfreak07's Avatar
lol at this
I do have some of these laying around, how much you give for one and I will ship it to ya! Send me a pm and let me know
