Weird headlight problem?
Ok . I have read all of the fixes and whatnot for the headlights. I just replaced the gears in my drivers side motor, Its working fine now. But the left side has a brand new motor in it since i got into a fender bender. It worked for about a month or two then hasnt worked since. It made no grinding noises like my drivers side and the light comes on so Its not a corrosion problem. I manually put the light up and it goes down fine then for the first couple of times i turn them on and off it goes up and down , then it just stops going up? thanks.
