I want to break something
Well, not really, but I want some more power.
I want to do a cam change, I really like the TR230 and after an extensive search, I have found nothing but great comments and reviews of the cam. Before I purchase, I would like to ask you guys if you agree or is there another option you would suggest.
I have higher mileage so I am going to do the lifters at the same time (I believe they are making noise also). Upon doing this, do you think I should change the heads? I want to keep the cost down. If I change the heads, I would most likely just pick up a set of used 243's for 5-600. Is the performance advantage worth the extra money?
My mods are as follows:
Lid, ported TB
Full exhaust: LT's, Y-pipe, cat-back
Yank SS4000 stall
3.42 gear (May go with a 3.73 down the road)
Lid, ported TB
Yank SS4000 stall
I have stock 241's on there now. On the stock engine, I'm putting 320 HP and 321 TQ to the rear wheels. If anything, I would like to stay with the stock heads to save the extra coin and the fact I have had no issues with them, but If I'm going to gain a significant amount by changing the heads, I may go that route.
I am currently rebuilding my motor and I'm going to run the tr230 and stock 243s. The heads have been milled to 58cc chambers and they have patriot dual springs but other than that they are stock. I am also on a tight budget and after alot of reading I think this will be a great setup for my street/strip car.
IMO save your money for "good" heads.
I should mention I bought the heads already milled and with springs for $410 in the classified section. I spent $100 to have them checked for cracks and flatness. I suppose if you bought everything new it might not be worth the money.
