4l80e pressure test
4l80e pressure test
still having problems with my manuel v/b, i called Transgo, they felt it was low fluid pressure, which is kind of the way i was leaning-i ordered a gauge, and am gonna ck it tomorrow-i think the book at a wide range of pressures for the diff gear selection-what should i be looking for in the way of psi that would tell me im ok-i assume higher engine speed would be higher pressure, to better operate the clutches
Closed ex-Sponsor Account
Yes you can. If you blocked any feeds in the pump let me know I can adjust for that. My full manual kit is designed so you do not have to teardown the transmission to install. It is can be adapted to most modifications out there.
