What power should I make and what et range should I Run In with mph???
Motor: 383 LT1, Cola crank, Eagle H-beam rods, JE pistons (22cc dish), Blower Cam, Stock Heads and Intake with 9:1 Compression and D1 or D1SC Procharger with around 12-14 psi.
Trans: Stock T56 with New Centerforce Clutch
Rear: Stock 10 Bolt 3.42 Gears (Yes I know Trans and Rear are pretty much stock but im not gonna run it at the track more then 3 or 4 times a year.)
Suspension: Only SFC for now
Tires: Mickey Thompson Street Radials either P315/35R17 or P295/45R17
Weight: Full Weight Interior
to run any decent times your going to need a whole suspesion, rearend, clutch, trans. The centerforce will not most likely hold the power you will be making (500-600rwhp).
Running the car as you have it setup now I would guess low 12's @125ish.
Could it go 10's? sure, with a high 1.4 60ft. To get them will cost you just as much as it did to build the motor.
Id go:
ST clutch, 9 inch, hi hp steel/chromly DS, Viper internal t-56, Umi/Bmr/Spohn/etc suspension, 15x10/15x4 slicks and skinnies. Thats you ticket to 10's.
Id go:
thanks for the input guys. probably not gonna mess with the trans as im looking to go to a built t400 so im assuming the trans will be fine for street driving as im only looking at 3-7 total track passes this year. after the motor is done a rear is definitely gonna happen. what would you guys suggest for rear ends with this setup and what would you suggest for heads instead of stock with a blower setup? also who makes good blower cams?
im thinking s60, moser 9 in or fab 9 for the rear. what would be my best option for rears? not looking to spend a ton of money but still have it hold up under 500-600 rwhp. also what sorta budget heads, cam and intake would you guys run on this shortblock?
