what are the normal values I should be seeing for trans temp, oil temp, etc...
so I've got an Aeroforce Interceptor now, and mainly I'm using it to monitor things that should have been on the gauge cluster, like oil pressure, oil temperature, and things like that. in addition to those, what about the other normal operating numbers for things like transmission temperature, knock, engine load, coolant temperature... etc.
trans is usually around 195 but ive seen it up to 220 which isnt good. you want knock to be 0. engine load is just how hard your pushing it. oil pressure moves alot--- at idle somewhere around 25-40 and way up when ur on it.
