Low coolant light...lots of coolant... ??????
When the car warms up to operating temp the coolant light comes on and stays on until I shut it down. Plenty of fluid in the radiator and lots in the reservoir. Car does not overheat. What could be the problem? Thanks
Ryan
98 Z28
Ryan
98 Z28
thanx for this info. that clears it up for me. see i figured mine didnt have a low coolant light because it never comes on for a sec when key is on run. also not showing in my service manual
I looked up the coolant sensor. I see it's a small black box. Is there another piece inside the radiator? Can that sensor be cleaned.....like with electrical parts cleaner?
IMO, If I went through the trouble of taking a 10 year old low coolant sensor, I would not clean it. I'd replace it with a new one from autozone for a couple of bucks or just unplug it.
I did the one on my 99 just recently, and my 2002 did not come with one.
Save the manuals!
I had the same symptoms and it was a bad coolant level sensor. If you are going to go to the trouble to partially drain the radiator to get the thing out, you'll probably want to have a spare sensor ready to go if you find your old one is clean! (At 10 years, you're due for a new one. My 99 lasted me just over 9 years and 80K.)
http://www.rockauto.com/catalog/raframecatalog.php
Here ya go-you will find a pix and all- rock auto 45.00
