Stock Bottom & Boost - Reliability List
I am wanting to make a comparative list of how long the LS1 stock bottom end has lasted under boost and eventually make it a sticky. Generally I see everyone say 550rwhp, I just want to see how valid this statement roughly is.
So the people I want to reply in the thread are ones who have ran boost on a stock bottom end (pistons, rings, rods). Even if you broke something in the motor, still post up. Post only cars you own(ed).
Here is the format I'd like to see it in:
- Type of Forced Induction (Turbo/Supercharger)
- Boost Amount / RWHP
- Miles on the car when FI installed
- Miles ran since FI has been on the car (ie: current mileage)
- IF you broke the motor, list what was broken.
__________________________________________________ ________________
TYPE ----- BOOST -- RWHP -- INSTALL -- SINCE -- BROKE?
T70 --------- 8 --------- xxx ----- 82k ------ 85k ------ N
STS --------- 5 --------- 453 ----- 18k ------ 37k ----- N
TC-76 ------- 9-10 ----- xxx ------ 26k ------ 32k ----- N
76gts ------- 12 -------- xxx ------ 55k ----- 63k ------ N
D1SC ------- 11 -------- xxx ------ 65k ----- 66k ------ Y
P1SC ------- 10 -------- xxx ----- ~80k ---- 120k ----- N
STS 76mm -- 5-15 ------ xxx ------ 109k --- 113k ----- N
P1SC ------- 7 --------- 489 ------ 28k ----- 50k ------ Y
T70 -------- 10 -------- xxx ------ 140k ---- 143k ----- N
APS Twin --- 7 --------- 508 ------ 89k ----- 105k ---- N
APS Twin --- 8 --------- xxx ------- 21k ----- 35k ----- N
D1SC ------- ? --------- 560 ------ 60k ----- 70k ----- N
P1SC ------- 8 --------- xxx ------- 79k ---- 81k ----- N
APS Twin --- 10 -------- 585 ------ 61k ----- 65k ----- N
D1SC ------- 8 --------- 475 ------ 48k ----- 54k ----- N
F1A --------- 6 -------- 540 ------ xxx ------ xxx ----- N
STS -------- 5-8 ------- 460 ------ 61k ----- 75k ----- N
D1SC ------- 10 -------- 612 ------ 0k ------ 11k ----- N
PTS 67mm --- 7 -------- 507 ------ 35k ----- 50k ----- N
D1SC -------- 7 -------- 500 ------ 29k ----- 39k ----- N
STS --------- 7 -------- xxx ------- 80k ----- 5k ------ Y
Vortech T ----10 ------- 640 ------ 58k ----- 67k ----- N
76GTS STS --- x ------- 626 ------ 43k ----- 43k ----- Y
STS 67mm --- 10 ------ 550 ------ 60k ------ 80k ----- N
D1SC --------- 7 ------ 523 ------ 34k ------ 38k ----- N
T76 ---------- 16 ----- 580 ------ ??? ------- 8kms --- N
D1SC -------- 10 ------ 540 ------ 30k ------ 34k ----- Y
T76 ---------- 17 ----- 580 ------ ??? ------- 10k ----- Y
P1SC -------- 13 ------ 588 ----- 36k ------- 50k ----- N
Kenne Bell ---- 8 ------ 560 ------ 10k ------- 24k ---- N
Incon TT ----- 8 ------ 525 ------ 25k ------- 85k ---- N
P1SC -------- 7.5 ----- 450 ------ 52k ------- 107k --- N
APS Twin ---- 10 ------ 625 ------ 101k ----- 111k --- N
MP112 ------- 7.5 ----- 495 ------ 79k ------- 81k ---- Y
MP112 ------- 6.5 ----- 518 ------ 65k -------- 66k --- N
D1SC -------- 8 ------- 590 ------ 39k -------- 50k --- N
D1SC -------- 7 ------- 520 ------ 98k ------- 135k --- N
D1SC -------- 9 ------- 580 ------ 65k -------- 88k --- N
Updated to post #100
Here's a start on what usually breaks.
http://forums.corvetteforum.com/c5-f...ottom-end.html
I run 8#s on a stock LS1 with 85,000 miles.Car goes 127 in the 1/4 so not making big power.Single T70 turbo.Maybe 3000 miles boosted.
The following users liked this post:
tdmaker (03-24-2022)
1 Post
- Boost Amount
I will create a list once I get a decent amount of entries. Thanks .
- Boost Amount
- 5PSI
- 18K miles when installed
- 37K miles when removed.
Never broke anything in motor. Only wear noted on engine H/C swap afterwards was excessive wear on forward-most cam bearing. Cylinders, pistons etc had some carbon buildup, but were otherwise in excellent shape.
Car dynoed 453RWHP/ 432RWTQ with a 11.1 to 1 AFR on a 2-bar SD tune.
76gts
~12 psi (added 317's)
55,000
at 60,000 now
still running fine, plan on pulling it out that way this spring for a forged bottom end
the motor held up to a good amount of high IAT's and knock because my IC was past its capabilities this year and I just kept pushing it but it held up...guess I was just lucky.
55,000
at 60,000 now
D1SC with FMIC, 224/227 .560/.560 114lsa cam, full exhaust
11psi
65,000
65,750
Broken ring lands on #7
Never had it on the dyno. I tried to tune it myself on the street with EFI Live and it ran hard while it lasted which wasn't long. First sign of trouble was when it started blowing the dipstick up under boost.
11psi
65,000
65,750
TECH Cry Baby BOSS APPROVED!
P1SC with a FMIC with 10 pounds of boost for over 3 years (525 rwhp)
Had over 80,000 miles when I went Procharger
Built a forged engine when the stock engine had about 120,000 miles. Never had an issue with the engine and boost
Daily driver with no 1/4 time.
Now the tranny...
Now the tranny...
my 5.3L calculated with my ET/mph to 640HP car weighs 3660 w/ me in it, and 10.30 @ 131mph, I cant build a lot of boost off the line and it dont hit full boost till after the 60ft, im also blowing through my converter higher RPMs than I should going through the traps at 7500.. 3.50 gears w/ 29.5" tall tires. So im sure it makes more HP than it calculates out to.
Stock 5.3L shortblock (junkyard.. mileage unknown)
15psi boost
50hp shot of nitrous.
Living strong going on 3 years.
15psi boost
8 sec potential, 12 sec slip
P-1SC procharger with midlength headers & borla catback (entire engine 100% bone stock)
7psi (3.5" dual intercoolers)
installed at around 28k miles
broke driveshaft & rear end at about 35k miles (1st track attempt)
broke #5 ringland at 50k miles
made 489rwhp at the time
I guess it would be silly but I would like to see someone go for just forged pistons and see how much power they could make.I'm still surprized you don't hear on any broken stock rod bolts and yet a lot of people think it's critical to replace them.I think the tune is the most critical part in keeping a stocker alive.
- MasterPower T70 Turbo on 2000 Bone Stock 5.3 with 140k miles
- 10 psi last season/499 rwhp
- 108,xxx on truck 140,xxx on engine
- 3k miles on Turbo setup
- Have'nt broke any engine parts yet, but blew two TH400 cases. (That was my fault tho)
- Type of Forced Induction - APS Twin Turbo
- Boost Amount - 7psi (made 508rwhp/513rwtq)
- Miles on the car when FI installed - 89k
- Miles ran since FI has been on the car - Put it in storage with 105k on it. I DD the heck out of the thing in the warmer months.
The car traps 126 in the 1/4. I ONLY run street tires at the moment because of the 10bolt so can't launch too hard. The tires are my fuse. And this is also my DD so I am very happy with it. It runs whatever it runs at the track.
mods in sig...
Stock LS2 short block has never been out of the car... now 761rwhp 645rwtq on boost only (no N2O) 31,000+ miles.
the car was S/C'd right after I bought it new back in '05, I only put 2000 miles on it waiting for the S/C kit to come in... the very first setup netted 620rwhp 518rwtq back then... It's ALL about the tune...
P.S. this car is set up for standing mile, it gets raced every chance I get...
D1SC at 8psi
installed at 60k now at 70K
30+ track runs
makes 560rwhp on stock 98 long block, 224-228 114 cam
never had a head off and hope it holds together one more season... but if not
30+ track runs
