Using Rail Feed as a Return?
On my TT vette I'm upgrading to a Lonnies Performance dual intank pump setup, and I plan on welding -8 AN fittings on both sides of the rail as a feed.
Can I use the stock feed port on the rail as a return with no issues? Just seems like a wierd placement, but I don't see why it won't work.
Kleeborp the Moderator™
What is keeping you from going to aftermarket rails?
I can't think of a good reason why what you are planning to do wouldn't work though...a couple years back Arizona Power and Sound (before they went out of business) had a piece that went in place of the pulse damper on the stock rails and made it a return port.
