Big Time Problems
Old 01-31-2009, 05:01 PM
RareBreed0295's Avatar
Default Big Time Problems
I recently installed a Moser 12 bolt with 3.73s in the hawk. For the past few weeks, everything has worked normally and i havent heard any whining from the rearend. Now there is whining when i let off the gas and there is vibrating coming from the rear. The vibrating of the car is very noticeable when i let of the gas. I jacked the car up and the wheels were very hard to turn and there was about 6 inches of backlash on the tires when rolling them to each side. Any ideas what the problems could be? Thanks for any help.
Old 01-31-2009, 06:31 PM
9000th01ss's Avatar
Take the cover off and look.
You might get a hundred "could be's" here, and they might all be wrong. I don't see the point.
Old 02-01-2009, 06:12 AM
EPP
EPP's Avatar
I'll bet the torque arm bolts are loose at the rear. Bob
Old 02-02-2009, 01:15 AM
silverLSWON's Avatar
torque arm bolts, drive shaft bolts, loose pinion nut. check all your bolts for starters
Old 02-02-2009, 05:16 PM
Alright. Ill try that stuff first. Thanks
