Oil Pan Torque??
Old 02-02-2009, 10:19 PM
JB_97ws6TA's Avatar
Default Oil Pan Torque??
I torqued the oil pan to 130 in lbs like the book called for and it seems like I am leaving a couple of drops in the driveway and it seems to be coming out of the weephole in the bellhousing dust cover. I used RTV around the rear main and about one inch into the flats on the block. Do you guys think that a little bit more torque could cure this or am I going to have to pull the pan back out??
Old 02-02-2009, 10:42 PM
shbox's Avatar
Oil Pan Corner Bolts/Studs 15 lb. ft.
Oil Pan Side Rail Bolts 106 lb. in.
are the factory specs.
Old 02-02-2009, 11:42 PM
Formula350's Avatar
You didn't get the one piece rubber gasket?! I'd say that's your first mistake
Old 02-03-2009, 07:33 AM
leadfoot4's Avatar
I don't know about that.... I've had two different "one-piecers" on my LT-1, and both times used a little RTV around the radius in the front and rear of the pan, but I still get a little "weepage". Annoying as hell...
Old 02-03-2009, 08:42 AM
JB_97ws6TA's Avatar
it is a one piece and yes you still use RTV
Old 02-03-2009, 05:36 PM
redhot lt-1's Avatar
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Quick Reply: Oil Pan Torque??
