Air leak
Air leak
I changed my water pump about two weeks ago in the process I removed the throttle Body, yesterday I notice that my RPMs at idle while in drive is 600 to 616 use to be around 550. Last night I check the the gasket behind the throttle body and all looks good. I did clean it when I had pulled it off during the pump install and also remove the sensors. I sprayed the intake cleaner to check for leaks around the throttle body but could not find it. So I'm thinking it could be on of the sensors that I removed??
