Quick Hose end question
I am going to re-doing my fuel system the right way now that I have added a turbo and bigger injectors.
My question regards the use of hose ends such as this
http://store.summitracing.com/partde...0&autoview=sku
I have never used fittings such as this, only barb fittings and lots of hose clamps. So how exactly do these fittings seal against 50+psi of fuel pressure?
Do you just insert the hose in the fitting and its done?
I will be using all braided stainless hose's also
sorry this is probibly a dumb question
thanks,
Matt
thanks,
Matt
Call XRP. They have the best hoses in my opinion. You never get a snagged hand cut or burn yourself in the braided lines. You will love these when you see them. The ID is larger and flows more that a standard braided line.
Good luck with your hose.
thanks,
Matt
thanks,
Matt
