just bought emerica4601's old T/A!
External Engine
Hurst Short Shifter
Stage II clutch
ws6store.com short stick
hurst shifter **** (will also come with black shift **** w/ silver firebird logo from ws6store.com)
K&N replacement ram-air filter (replaced with brand new one 2 months ago)
SLP smooth bellows
Removed E.G.R.
Removed A.I.R.
Pacesetter Ceramic-coated Longtube headers
Summit Racing 3” True Dual System
Powersticks 18" mufflers
March Under-drive pulley
BBK 52mm Twin Throttle body
NGK TR55 spark plugs
Taylor 8.0mm Plug wires
MSD Ignition Coil
Summit Racing Opti-Spark Distributor
Racetronix 225lph Fuel pump
GM Zexel Torsen 7.5” Differential
Motive 4.10 Ratio Ring and Pinion
T/A Performance Girdle Cover
Summit Racing Full Rear Install Kit
PCMforLESS computer tuning
Internal Engine
Comp hardened 7.200” Pushrods
Crane .060” Valvespring seats
Crane Double valvesprings
Crane Gold Self Aligning 1.6 ratio Roller rockers
Comp valvespring retainers
Comp 10° valvespring locks
Comp XE 230/236 .510/.520 112 LSA Camshaft
GM Heavy Duty Solid roller timing chain
Thunder Racing camshaft swap gaskets
Suspension
Lakewood adjustable panhard rod
Lakewood boxed lower control arms
Edelbrock torque arm
Appearance
Blackbird ram air hood stripes
Grand sport twin hash stripes
Black trans am door overlays
Black phoenix nose overlay
White Trans am/phoenix center tail overlay
VHT niteshade tail lights, third brake light, side markers
Ractive Oval chrome tips
Black CETA bumper
Black Painted OEM WS6 wheels -17x9
8k HID's with H4 housing unit
Other
Aluminum Strut Tower Brace
Aluminum 5.7L rear badge
Aluminum Cover for fuse box
Brushed Aluminum "trans am" lettering above glove compartment
Trans am bezel
Autometer tripple gauge pod pillar
Autometer phantom voltmeter
Autometer phantom oil pressure
Autometer phantom water temperature
Autometer phantom fuel pressure 2 5/8 center a/c hole
Hurst Short Shifter
Stage II clutch
SLP smooth bellows
Removed E.G.R.
Removed A.I.R.
MSD Ignition Coil
Internal Engine
Suspension
Appearance
Black CETA bumper
Other
Trans am bezel
