160lb injectors and a injector driver box
I read somewhere that you are not supposed to use an AEM injector driver box with 160lb injectors (something to do with the ohms.) I currently have both the AEM injector driver box and 8 160lb injectors... I will be running E85/E98 through these injectors and then for pump gas if I have to resort to that I have a set of 96lb injectors. I just wanna make sure before I install this AEM IDB that it's going to be couture. Either way I am going to have to run this aem box or a resistor for the injectors. Let me know your thoughts! Thanks in advance...
Not sure on the AEM box but we have run 160 inj with the VersaFueler. But if you need to control that much fuel I would rec. a complete fuel system controler like a BigStuff.
Nate
Nate
I'll be running a AEM EMS. It's on order and should be here mid this month. I know nobody around these parts runs em that much. But my bro has had extremely good luck with them as well as the supra boys... I don't see why they aren't used much. Plug and play and nearly as much parameters that can be changed as any other EMS....Ohh did I mention a 1/3 the price?
Thanks for your advice. You're a great help!
