Idling High
Old 02-05-2009, 09:52 AM
Rafko's Avatar
Default Idling High
Just swapped my 88 s10 to a 6.0 out of a 2003 pick up...it is stock other than the transmission...it is a turbo 350 with a 3800 stall..when i crank it up it will idle normal and sometimes it will idle up high by itself...what could be the cause...it has the stock tune...just has disabled vats....
Old 02-05-2009, 10:40 AM
ZL1Killa's Avatar
how high idle are you talking?
the base idle tables and idle tables can be adjusted
Old 02-05-2009, 09:09 PM
Rafko's Avatar
sometimes if you crank it, it will starting idling...then accelerating..?...like someone is pressing the gas pedal it will go up to about 1700 RPMS...and then if i rev it it will go back to idling..?
Old 02-08-2009, 06:58 PM
Rafko's Avatar
Ttt....
