p1 procharger kit on my car
so i recently sold my snowmobile and have some money to play around with and im tossing around the idea of picking up a used p1 procharger kit with the twin intercoolers...
my questions are: what kind of power would it make on my car with its current mods in sig?
would it be safe to just bolt it on, tune it, etc...i wouldnt need any more supporting mods?
could my bottom end handle it?
any help is appreciated...thanks!!!
8 psi with your mods will get you around 140 more additional rwhp. I would go with 60 lb injectors, and 255 Walbro fuel pump and get a good tune.
This list may help you out.
http://www.exoticperformanceplus.com....html?item=540 Bob
Get good gaskets and stud the heads it will hold more that 8 psi just a real good tune. Ive seen 18psi on a stock 5.3 on the dyno. That was probobly ***** and grins, but that was with race gas too. I dought they race it with that setup but it ran a 6.5 sec. 1/8 in a fairmont
Is the transmission stock? I know it's got a stall. But 60e's don't last for **** with power, especially non built ones... And then your rear, any work done in that area? Those are the only upgrades I think you need to be reliable as long as you aren't trying to push more then 8lbs. Then you might wanna start looking for a shortblock and heads too Good luck on your decision though!
