Any experience with lunati 232/238 cam?
Hey all. Im looking to toss a cam in my motor soon. I think I've pretty much settled on their 232/238@.050 .599"/.601" 113LSA grind.
Im wondering if anyone is running this cam or a cam similar with just bolt ons and what kind of power your making. I currently have QTP long tubes, custom 3" oval Y and custom cat back. Also running an SLP lid, filter, 85mm MAF and BBK 85mm Throttle Body.
I will most likely be adding the set of 241 LS6 heads that I picked up a while back also.
Any experience would he helpful.
Thanks!
Thanks!
formerly twolow02fransen (2014-1-2)
thats about the same size id like to run in my 6.0 as far as ptv goes i have no clue but i know your going to want to bump up the compression with that cam you have those 241s all youll have to do is get them milled good port job and you will have a nice setup id say
I have the cam in my sig. right now, I was thinking about the 232/238 cam when I seen it but now VooDoo has a 237/243 cam out with .600" which I'm in the the process of discussing with Harold Brookshire (the guy that created the VooDoo line) to see what kind of results it would have on our LSx motors.
Thanks!
Thanks!
Do a search on www.chevelles.com/forums for "Voodoo Cam" or "UDHarold", you can find more info there.
