Vic Jr guys, what do you do with the cannister purge valve?
Old 02-06-2009, 07:53 PM
ss1129's Avatar
Default Vic Jr guys, what do you do with the cannister purge valve?
I just realized that there is no adapter on the vic jr for it. Any ideas?
Old 02-06-2009, 09:06 PM
Lextech's Avatar
Here is what I did on my truck. I have run it like this for about 2 years. I used an aluminum vacuum manifold and drilled out a port for the purge and drilled and tapped it for the retaining bolts. The end of the vacuum manifold has a 3/8" fitting that gets plumbed to the back of the intake for its vacuum source. I used tubing from a truck shop for air brakes to connect the Purge canister to the Purge solenoid.
Jeff
Attached Thumbnails Vic Jr guys, what do you do with the cannister purge valve?-000_0162-small-.jpg
Old 02-07-2009, 08:44 AM
ss1129's Avatar
Does anybody just tap the elbow or manifold it self and install a quick connect on it? Or, does anyone just eliminate the purge valve? Does it matter if its actually there?
