2007 corvette pinout help
http://www.ls2.com/forums/showthread...hreadid=405808
That should be all you'll need. Print them out because sometimes the pages are not available.
9 Second Club/LS1TECH Sponsor
We offer a full stand alone rework service for the Corvette harnesses, or a brand new custom harness if needed.
On the newer Gen-IV engines our rework includes adding the fuse block, fuel pump relay, diagnostic port, check engine light, and accel pedal harness, as well as getting rid of what's not needed.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
I have an e38 computer running a L92 Escalade engine, swapped into a 95 Tahoe, switched to the more desirable Corvette pedal and had APPS codes. I searched and found that pins D and F needed to be swapped, all APPS codes gone, works great! Wire colors brown and white/black get swapped. Seems to be a great mystery, so I thought I'd share. This is from the factory Escalade wiring to the newer, 25835421 "Vette pedal.
