LS1/Vortec Intake swap
Old 02-11-2009, 09:50 AM
Thick_Ryan's Avatar
Default LS1/Vortec Intake swap
I have a 5.3 Vortec and I am swapping an LS1 intake onto it. I heard there are cooler lines below the intake that also need swapped. I'm having a hard time finding the LS1 intake cooler lines, can someone point me in the direction I can find those and how much I am likely to pay.
Thanks
Old 02-11-2009, 10:12 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
if you are doing that, and going from the spider style coolant tubes, you need to get the caps for the back as well, and 4 gaskets. use the stock bolts.
front crossover tube
rear caps
you will need 2
and the gaskets you will need 4 of them
Old 02-11-2009, 10:22 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you're running the truck accessories, I believe you have to do something about the idler near the top/drivers side as well. Check out the truck forum, but someone has an easy relocation kit for this swap and that makes it nice.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-11-2009, 12:40 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
yah, its def in the way...that taller intake isnt just for looks.
Quick Reply: LS1/Vortec Intake swap
