LS1 Mechanical TB linkage - not cable
Old 02-11-2009, 05:15 PM
Nashty's Avatar
Default LS1 Mechanical TB linkage - not cable
Cleaned up the intake, removed the fuel rail bosses and made new tabs that use the stock intake bolts. Filled the PCV cavity with clear epoxy (taped over right now). Then removed the TB cable boss off the intake and made me a mechanical linkage.
Before it was powdercoated and TB cable boss excised.
I'll operate it from a cable off the rear of the motor. You can also see how I'm mounting the coils on the intake. I wrapped the valve covers with carbon fiber too.
