Need help!!! Cam gear and crank gear
Okay i'm installing a double rollmaster timing chain and I am using the ls1howto to help with everything but picture i believe are for a stock chain.
But my question is which marks to i use on the crank gear. There is a dot on the tooth and a dot on the very front of the crank gear. Everything seems to line up perfectly when I use the dot on the tooth of the crank gear.
Can anyone help me who has installed the double rollmaster timing set?
Just want to make sure i have it installed properly before moving ahead.
Thanks in advance!!
Thanks in advance!!
