Tach signal wire off PCM?
Old 02-12-2009, 03:07 PM
LM97Z's Avatar
Default Tach signal wire off PCM?
Which wire is it, its a 97 with an OBDII, the coil (factory) only has 2 wires coming off of it, i was having problems with my Window switch RPM readings, but the switch checked out good, i had it hooked to the "green" wire off the coil.
Old 02-12-2009, 05:45 PM
nemss1's Avatar
info frm the PCM is carried the the serial data wire (green to purple) carries info for OBD2 port, tach signal, oil pressure and fuel level
Old 02-13-2009, 06:40 PM
ak95ta's Avatar
They didn't start that until 99, hes got a 97. I always thought it was the white wire. I don't have my book with me though.
Old 02-13-2009, 06:47 PM
ak95ta's Avatar
OK I found it online. It is the white wire that goes through the blue plug C230, pin D, then to the tach. On the red plug off the back of the PCM, it is A13, still a white wire.
Old 02-14-2009, 01:51 AM
LM97Z's Avatar
Thanks, found out its the "white" wire off the ICM, i had the window switch "tach" wire hooked too the "green" wire off the coil, RPMs were reading iratic.
