losing fuel pressure?????
Old 02-12-2009, 07:18 PM
ozzman98's Avatar
Default losing fuel pressure?????
i have a 1998 ss camaro and i keep losing fuel pressure when there is a load on the car. when i try to do a pull the pressure drop to 38lbs. i have already replaced the fuel pump, regulator, and filter. still no chang. car has been modded with full ls6 short block with ls6 heads, ms3 cam/valvetrain, bbk intake. estimated 440rwhp. any help will be apprciated
Old 02-14-2009, 11:42 AM
NAAllTheWay's Avatar
guess nobody knows so far, that sux man
Old 02-14-2009, 11:54 AM
LSmokin1's Avatar
the line that connects the pump to feed line in the tank could have been kinked or the fuel sock is clogged in some way. Both of which has happened to me.
Old 02-14-2009, 12:37 PM
any other possibilities?
Old 02-17-2009, 04:55 AM
vette_c6's Avatar
well if you have fuel system in your car ,, check the the Hoses ,, if they are big ,, for sure u will lose pressure
check the hoses ,, are they 4 an or 6 an or 8 an
i got a theory i use it myself ,,, if i use Welbro 255 inside the TANK ,,, + Bosch 430
with 8 AN Hose from the Bosch to the Fuel rail ,, i will lose pressure ,,, so i will use 2 Bosch
so check your hoses they might be to big ,,, i tried my Theory here in my country ,, and i guess i am right about it ,,,
hope that info will help u
Old 02-23-2009, 11:33 PM
ozzman98's Avatar
the car is fixed. pulled the pump back out and the line was pinche where the spring is on the unit. put a new hose in and holds great. thanks for all the help guys
Old 02-24-2009, 12:13 AM
you owe me lunch for fixing that for you.
