Need Help..w/ Hooking up Daul gauge pod & gauges.
Does any have a link to a site or some of their on trial and
error hints and tips for hooking up a dual pillar pod w/ 2 - 1/16"
Auto Meter Phantom A/F ratio and Trans Temp gauges. Any Help with mounting the
pod.. To the wires that need to be connected,& Maybe some short cuts to
make the job easier--- would be greatly appreciated.
Thanks
Christian
Thanks
Christian
Re: Need Help..w/ Hooking up Daul gauge pod & gauges.
For A/F tap into the purple wire coming off of the O2 sensor.
I pulled my dash and ran the wires through the passenger side firewall. Pull the computer & bracket in the engine compartment and you will see the rubber gromett. I also got a fuse block from boaters world so everything is on its own fuse. good luck with it.
