How do i get a purge like this? (pic)
I am a big fan of impressive looking purge systems (i know they dont do a thing other than waste nitrous).
I found this picture and i want a purge kit that will spray this size and amount. But how do you do it?
Re: How do i get a purge like this? (pic)
It's relative to the size of the nozzle at the end of the line. Try different sizes and shapes of the exits on your purge until you get what you want.
STF veteran / 10 second club
Well what about running a 4an line from the purge solenoid to a annular fogger nozzle?
any recommendations on how to run something like that.ive seen the copper tubing typical setups and they go like 4-5 feet because the hole just doesnt flow enough. so i would think a large opening correct?
You will get more velocity with a smaller opening. It's like a water hose, if you put your thumb over the end and close up most of the opening, the water will shoot farther.
i would guess you will also need a bigger solinoid like a cheater or proshot to get that much flow. now you got me thinking.
I called sean wasnt in apparently....guy that answered the phone said he was a nitrous guy i guess.
well what do you think, cheater solenoid with a 3/16 copper line coming out??? Maybe just run a 4an line open ended and just mount it so it sprays right out of the braided open 4an line.
I'll attach a 4an line to a bottle tomorrow and just open it and see how far it sprays out of a open ended 4an...
SSU Moderator
someone used to use a pro shot sol. and run two copper lines. I wanna say the fog comes from a mighty full bottle at full pressure and the line has to be crimped to a thin slit at the end. I never got mine for fog real good, but I never had a bottle heater either.
