what size injectors so i go with
MS4 cam, ls6 lpe heads, ported fast 90/90, kooks LT 346ci
I'm sure i need about a 40lbs injectors but my question is if i run nitrous, say 100 shot wouldn't 40 be to small. first time thinking about nitrous and not sure how to add up nitrous into injector size. Do you just add 100hp to adj. for nitrous? thanks
keith
keith
A wet system will provide it's own fuel, no need to compensate for fueling via the injectors. 36's will give you a little room to grow and 42's will give you a bunch of room to grow. These flow figures are at 3 bar and the LS fuel system runs at 4 bar. 36's would be approximately 41's and 42's would be approximately 48's.
Killer price on killer injectors here.
Rich, FICINJECTORS, at Fuel Injector Connection can help you if you have further questions.
