I need help!!
Old 02-17-2009, 08:01 PM
LM97Z's Avatar
Default I need help!!
If theres any nitrous guys out there with window switches on your LT1s, please help, i got my window switch back today, i'll be installing it again tomorrow, but now i'm confused, they wrote some things on the box, they tested it on an LS1 (no LT1 cars available), i have an LT1, they said i need to set my tach setting @ 000, then hook the green wire to the "coil trigger", which wire is the coil trigger, does anyone know? How do you guys have your window switches hooked up for the LT1?
I don't think they realize its for an LT1 car, i only have 1 friggin coil, not 8, so before i install it & things don't work out, i need help!! According to the instruction sheet, it qoutes: "000= individual coil per cylinder systems where the tach wire is connected to the coil, connects to the wire for the coil." This sounds like an LS1 set-up, not LT1.
Old 02-18-2009, 12:41 AM
LM97Z's Avatar
Anyone
