Walbro High psi or Low psi?
Old 02-17-2009, 11:06 PM
LS1Silverado05's Avatar
Default Walbro High psi or Low psi?
Looking at Walbro pumps and it seems you select a high psi or low psi version when you order? What one do most people install? In my case the car will end up H/C with some Nitrous probably... Eventually injectors...
Old 02-18-2009, 02:04 PM
Nasty N8's Avatar
Your car requires the high PSI pump as the stock pressure is 58. Give me a call I keep them and the wire harness in stock.
Nate
