Adjustable FPR or Bigger injectors?
I want to run e85 and need more fuel delivery. I thought I found my solution bigger injectors, but a suggestion from another forum was to get an adjustable fpr to trigger in under boost. My concern with that is more pressure will eventually impede volume. What are your thoughts?
If you are boosted it is a good idea to run a boost reference regulator anyway. So bigger injectors will be better in the long run because higher fuel pressures will hinder your pumps performance as well!
