25mm rear swaybar?
25mm rear swaybar?
Hello, i have the bolt-in 25mm rear swaybar for street/strip. I seem to be getting some lean to the right side on the launch still. I was wondering how i can adjust/preload the end links to stop this? also what size end links should i use? i have the endlinks currently torqued down all the way which leads me to believe the spacer is too thick and no allowing enough preload? Please give me some input, thanks.
that may be an idea i will consider but i see a lot of people preloading the endlinks (or maybe im using the wrong length ones?) and being able to counteract the uneven launch/twist. so i was wondering if people could tell me what end links they are using and how they are preloading the bar?
