LS6 intake/PP TB installed! Now couple quick questions??
Ok just got it all done after my TB came in today. The car has been sitting with the battery disconnected for a month or more. Started right up, with a few sputters, and then held an idle real well. Oil pressure sensor is working so I didnt break that THANK GOD! But if I give it a little rev it will fall down to a couple hundred RPM's like its gonna die, then it will recover and hold an idle. Im pretty sure this is just it relearning after sitting for so long? What do you guys think? Any thing else to check?
I cant drive it since it only has storage insurance right now....
Josh
Josh
Ya that is what I was assuming, now my problem is that I need to adjust the throttle cable...its no where near full throttle when the pedal is on the floor. I dont think I had full throttle even before the bump stop mod....should have checked that a long time ago
edit: found it through a search...ive been here too long to make that mistake...its actually real easy to adjust
