lots of play in my rear shaft on a 4L60e
Old 02-21-2009, 12:12 AM
The Postman's Avatar
Default lots of play in my rear shaft on a 4L60e
put in a new TA mount tonight and also replaced my tailshaft seal. while i was doing this i noticed that the shaft u slide the driveshaft over has quite a bit of play in it from side to side and up and down, is this normal of could something be wore out inside?...
I've never noticed it before until now, just wanted to make sure it was ok or something i needed to get checked out.
thanks
Old 02-21-2009, 12:21 AM
9sec93's Avatar
definitely needs to be checked out. you say you replaced the rear seal so iam assuming it was leaking. im sure the loose shaft is what made the seal go bad. if it gets worse it could crack the tail housing of the trans.
Old 02-21-2009, 12:27 AM
it wasn't leaking really, just kinda wet around it so i went ahead and replaced it while I was there...after I put the driveshaft back into the tranny I couldn't move it no matter how hard I tried so I'm not sure what the deal is...I need one of the big tranny shops to chime in here..
oh and when i say PLAY...it was probably about 1/16-1/8in ...I just thought I could wiggle it too much
Old 02-21-2009, 09:14 AM
LS1Tech Sponsor
performabuilt's Avatar
The shaft would have considerable play without the yoke in. the shaft is supported via the yoke being on it with the bushing in the tail housing supporting it. So likley what you feel is normal.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-21-2009, 12:00 PM
alright man thanks!...I guess I was just paranoid since I have a lot of miles on the car and lately **** has been going wrong left and right....thanks a lot guys
Quick Reply: lots of play in my rear shaft on a 4L60e
