LS2 to 4l60E Ouestions??
I am doing an engine / trans swap in my 69 Chevelle. Putting an LS2 and 4l60E in it. The engine is a crate motor from GMPP (set up for a Corvette). The engine came with a 14" flexplate but had an adaptor for the Corvette attached to it. I was told that it could be removed from the flexplate (i did this). In putting the transmission and engine together, do I need any type of flexplate spacer? Or will they just go together? If anyone knows this would help. Thanks!!
Closed ex-Sponsor Account
Sound like you have an older style 4l60e Transmission or non LS engine type. If that is the case you need the spacer. Post pictures if possible.
