4000 pulse or 8000 pulse/mile
Old 02-22-2009, 01:26 PM
rubrhammer's Avatar
Default 4000 pulse or 8000 pulse/mile
I'm confused, a year ago I followed a thread to Dakota digital for a GM pass thru 8k pulse generator SEN-01-4160).I bought that but now I see a thread that lists in connector C100 a wire to go to a 4000Pulse VSS. I have a 2004 LM4 5.3 with a harness and computor from a 2005 Silverado 5.3. What do I REALLY need. This is going in a 65 Vette with a Muncie 4sp. Any help would be appreciated.
Bob
Old 02-22-2009, 07:30 PM
LS1MCSS's Avatar
You can use a 4K or an 8K pulse VSS as long as the pcm is tuned for the VSS output. Just make sure it's a two wire VSS so it sends the correct type of signal.
Old 02-23-2009, 08:48 PM
rubrhammer's Avatar
Thanks for the info. The ecm will need some stuff removed anyway so I'll let the tuner know what I have for VSS.
Bob
Old 02-23-2009, 09:16 PM
LS1MCSS's Avatar
What is he going to use to tune it? Early last year, when I checked, EFILive would only go down to 10 pulse per rev, while HP Tuners would go all the way to zero. EFI may have updated by now.
Quick Reply: 4000 pulse or 8000 pulse/mile
