maf question
maf question
slp 85mm high flow maf with matching sized intake cone filter and custom air bridge to fit the stock size coupler and tb. Will this work out? intuition tells me it should be fine. What do you guys say?
It would be ideal if the 85mm would fit the stock piping. Is it just a bored out stock one without the fin? help
you can get a brand new delco 85mm maf on ebay for $50 shipped. throw in a fast toys lid and the connector adapter, then youve got a real 85mm setup. all of this will run around the same price as an slp maf. in the future is you go to a fast 92 you will be presetup. plus your iat will be built into the maf and give a better reading.
