SLP spark plug removal socket
Old 02-25-2009, 04:24 PM
C_Rules's Avatar
Default SLP spark plug removal socket
So I just bought the slp spark plug removal socket. Basically its just an open ended socket that the spark plug stick out of which you can then turn with a wrench. its supposed to help out in those real tight spaces. im just curious to see if anyone had any experiences with this particular socket or one like it?
Old 02-25-2009, 04:29 PM
ssam98's Avatar
yes it works nice.
Old 02-25-2009, 04:32 PM
hyperzone's Avatar
had to go look for a picture of it... I haven't seen one like this till now. Interesting. Here it is.... SLP spark plug socket :
Old 02-25-2009, 04:36 PM
iceman15's Avatar
one of the best tools ever invented, saved me so many headaches
Old 02-25-2009, 04:41 PM
Red98a4SS's Avatar
excellent tool well worth the money
Old 02-25-2009, 04:57 PM
krill's Avatar
Yepp works good!
Old 02-25-2009, 05:10 PM
deerslayinrednek's Avatar
It's a breeze changing plugs....on an LT1 I change all but #2 from the bottom....and on an LS1 I change all but #8 from the top....no special sockets,ratchets, or swivels were needed
Old 02-25-2009, 05:42 PM
Fbody4Ever's Avatar
I have it and it has been helpful.
It is just a craftsman spark plug socket that's been cut pretty much in half, then the bottom where you would snap a ratchet in is drilled out to allow the spark plug to stick out. It's cheap enough that it might not be worth the hassle to make your own, but it's nothing special if someone wanted to try it and had the tools to get it done.
Old 02-25-2009, 05:49 PM
C_Rules's Avatar
cool sounds like i made a good investment then.
Old 02-25-2009, 05:51 PM
C_Rules's Avatar
you should do a write up then because most of the lt1 crowd has a pretty difficult time getting them out. share your secrets
Old 02-25-2009, 06:19 PM
camar0corey's Avatar
Well worth the $20 or whatever the hell they are charging for it these days. I use mine on every plug change, this and a ratchet wrench.
Old 02-25-2009, 06:37 PM
FlamingChicken's Avatar
the funny thing about that socket is its a craftsman sold for 29.95 (last i checked). snap on sells a shorty like that for 25. they work well regardless.
Old 02-25-2009, 10:14 PM
BALLSS's Avatar
these work
http://www.headersockets.com/
or just cut down a standard socket..
Old 02-25-2009, 10:38 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I'm sure it probably works great. I used a socket and a pair of vice grips.
Old 02-25-2009, 10:58 PM
-DIABLO-'s Avatar
u dont have to buy it u can make one like i did i just use the one that i have and cut it with a dremmel u can cut it with anithing that cuts metal save ur self 20 bucks and works great
Old 02-25-2009, 11:22 PM
93TAJ.C.'s Avatar
^^word^^
Old 02-25-2009, 11:34 PM
lol I've heard horror stories about changing plugs in these F-bodies.....so I put it off for 8 months and 2 weeks ago I changed plugs in an LS1 and the next day I changed them in my LT1....Took about an hr and 15mins to change mine.
Old 02-26-2009, 12:44 AM
myltwon's Avatar
I made my own as well
just a few min on a bench grinder has saved me hours in plug changes
Quick Reply: SLP spark plug removal socket
