sbc swap into rx7
sbc swap into rx7
I am wanting to do a sbc 350 swap into a 2nd generation rx7... I have found a good mount kit from hinson supercars for the lsx motors but I was wondering if anyone knew if this kit would work for the older style 350 and also if I will need a custom fabricated oil pan or not and what type of headers people have used with these swaps
I have found the mount kit does anyone know if I need a custom fabricated oil pan.. All I have at grannys is a kit that includes it and I was going to order the mount kit seperate if someone could help me out it would be greatly appreciated.. Thanks
You need to go to the V8 X7 Forum for specifics. There is a ton of info there. This site is mainly for swaps that use the LS style small block. I think you are talking the older syle Chevy 350 (nothing wrong with that) You will find what you need there. I am a member, if you need info just let me know. I just removed a Vortec 350 and replaced it with a LS style 364 small block. Hope this helps
I appreciate the info and i will be joining that forum... Yea its a older sbc its a 327 with 400 heads it should be a fun project for us
