my ABS INOP light is on
would anyone know what could be causing this. Its a 02 camaro ss. ive checked fuses, and i dont get power to a whole section. also i cant turn on or off my traction control. anything will help
Its obviously something wrong with the ABS system. The reason you can't run off traction control is because the traction control and the ABS system are tied together. If your ABS is not working then neither will traction control. First thing to do is to look at each wheel and take a look at the wheel speed sensors. See if one of them is unplugged or the wire is cut or burned or something like that. If they all look fine then you need to get the ABS codes read and see whats going on. I am not sure if Autozone and places like that have the ability to read ABS codes or not but its worth a shot.
What do you mean you don't get power to a whole section? As in one of the fuses is blown?
