Timing Cover?
Old 02-26-2009, 06:54 PM
94Z28-MSTGKLR's Avatar
Question Timing Cover?
It's been so long I don't remember. Do you have to drop the front of the oil pan to replace the timing cover gasket. If so, does anyone know if you can replace the oilpan gasket with the trans still hooked up. If I remember right you could drop the pan by jacking up one side of the engine. Just curious. I have to replace the opti so I might as well reseal everything that is leaking...which is everything. lol!
Old 02-26-2009, 07:36 PM
ss.slp.ls1's Avatar
You have to undo the oil pan bolts, loosen all but the last two to drop the pan enough to get the timing cover off and on. If you look at the recent threads, you'll see one about how to change the oil pan gasket.
Old 02-26-2009, 07:46 PM
robsquikz28's Avatar
x2 ^ not that bad of a job
Quick Reply: Timing Cover?
