Easiest way to change the DRL?
LS1Tech Co-Founder
Re: Easiest way to change the DRL?
there is a single 10mm nut on the back of the headlight assembly that you need to remove. Then the entire assembly slides inwards and can be removed. Take those four (or five?) push-in plastic buttons off where the nose meets the support, under the front edge of the hood area. Pull the nose forward to get the headlight out.
Tony
Tony
