fuel problem
fuel problem
my car is acting up
when you floor it it pulls fine up till about 4800rpm and then it is almost like it goes to neutral and the a/f goes lean ,the car stops pulling and wont go higher in rpms to shift almost like bouncing on the limiter
if you back out of the throttle it will continue to pull and make the shift
sounds like fuel pressure to me,when i go wide open my pressure drops to about 50-52
it has done this a few times before and then stops doing it out of the blue
any ideas would be appreciated
