Will an electric trans pump work with the engine off
I was thinking about getting this pump, but have a question.
Can I use this at the track like the electric water pump I use to cool the coolant quickly with the engine off for hot laps at the drag strip. Will it still pump with the engine not running?
The whole point of that is to pump with the engine not running, while the car is being towed.
I guess if you could rig it to work with a fan mounted trans cooler running at the same time it might do something.
In the OP's idea, it would either work or not for cooling, if it didn't he would just be out the money of the pump.
