Lost tranny fluid!!!
Well I was driving yesterday, and the trans started to freewheel in gear, so I immediately downshifted to a lower gear, and that didn't work either. Pulled off the side of the road, couldn't see anything unusual due to the 6 inches of snow we got yesterday, so I check the trans fluid out of instinct. Damn near dry. My first thought is I toasted the tranny...after less than 300 miles!!! Called USAA for a tow and brought it back on base. My question is how bad could the tranny be hurt at this point? I might have went maybe a mile after it started acting up. And will I need to pull the TC to fill it with fluid if it was coming from one of my lines?
Thank performabuilt. I guess worst case scenario is that I'll be looking at one of your trannys for a replacement if it is completely jacked. Ill post results when when I pick up some trans fluid later
